Disables a BGP peer group and all its BGP neighbors.
| peer-group-name | Specifies a peer group. |
Disabled.
This command applies to the current VR or VRF context.
The following command disables the BGP peer group outer:
disable bgp peer-group outer
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
